A6 Compressor Clutch Plate
Posted: Sun Jul 19, 2026 9:36 am
by Ex313
AS you can see the rubber ring on my A6 clutch plate has disintegrated. Its an original 5" clutch on a 1971 GMC C1500. Given the rarity of factory delco clutches, can I use a plate from an aftermarket clutch? I am hoping to avoid tearing into the compressor more by replacing the entire clutch assembly. If I could just do the front plate that would make life a whole lot easier.
Re: A6 Compressor Clutch Plate
Posted: Mon Jul 20, 2026 7:49 am
by grumpy old man
Somewhere in my absolutely impeccable garage I have a new front plate from the compressor in a 2015 GMC sierra 1500. If you think it will fit it is yours. I never throw away good parts I just put them in hidden corners never to be seen again.
Dwight
