2011 Fusion, A/C works then switches to "heat from Hell" Long post
Posted: Mon Apr 20, 2026 7:34 pm
2011 Fusion SE 4 cyl, base A/C (not dual zone, not auto temp control). 175K miles. A/C appears to work good, nice cool temps out of the vents. Suddenly the A/C quits cooling and maximum heat comes out of the vents. A/C controls have not been touched when this happens. On a restart A/C may work fine for an extended period of time or switch to the "heat from hell (my wife's car and her description) after about 20 to 30 seconds of cold out of the vents. This problem also occurs when the HVAC setting is in vent mode. No adjustment to temperature control has an effect. Do not think it has happened while in heat mode.
This first occurred in '19. I replaced the HVAC control module (rebuilt Dorman, lifetime warrantee) and all was well until June '24 when the problem reoccurred. Replaced the HVAC module again along with the blend door actuator and problem reoccurred in Oct of 24. Replaced the HVAC module again (3rd time) but the heat from hell occurred during first drive after HVAC module replacement replacement. Installed a Motorcraft blend door actuator - no improvement. For the summer of '25 I set the A/C to max cool, removed the blend door actuator from the HVAC module (leaving the blend door module electrically connected and zip tied up under the dash). A/C worked great all summer/fall but unable to control cabin temp other than fan speed or A/C on/off.
I acquired scan software (Forscan) and the Ford workshop manual. One HVAC DTC: related to low batt voltage. Followed the test procedure for batt voltage (passed) and the direction was to replace the HVAC control module. 4th HVAC module replacement worked OK after install but heat from hell the next day driving. Checked DTCs - two this time. Both DTCs were communication errors between IPC instrument control panel and HVAC module and FDIM front display interface module and the HVAC module. Following the manual, it appears the HVAC module is at fault - I'm on the ragged edge of understanding this.
Has the Dorman rebuilt module become junk? Are there other options for an HVAC module (I have not found anything else)? I'd really like to solve this problem correctly, but I am beginning to daydream about machining a coupling/lever to mount on the HVAC asm and having a push/pull cable actuate the blend door (like the good old days).
