Help - flushing out wrong oil from AC system
Posted: Sun Dec 07, 2025 5:55 am
Hello everyone,
I have a 99 GM/Vauxhall Vectra that had a leak and I fixed by replacing some components, but did some mistakes along the way and need help to come up with a plan now... in fact not even using it until I can address
--->AC is working and cooling fine btw.
First, it uses a Delphi Harrison V5 compressor (still original from 99) that calls for 7.5oz of synthetic oil SAE J639
I have never worked with AC before and didn't know they had different oil viscosities too... thought it was one fits all or period specific, asked a shop and the guy said "we mostly use PAG46" so I went with it.. yes very dumb mistake, it should have PAG150 it seems... 1st error.
also when replacing hoses, cleaning etc, I am sure moisture entered the system... I washed the compressor insides (just the casing not the part were the pistons are, but still) and hoses were open for a while... 2nd error. (added a new dryer filter at least).
What is the best way to remove oil without disassembling everything again now? if the shop pulls vacuum from the high pressure/liquid side, will it work? I can also remove the fill bolt in the compressor and use a syringe to remove most in the sump there...
Also by researching this, found some saying that running too much/deep vacuum can boil the oil and damage seals, is that true? I refreshed most things and don't want to put at risk... just not sure how it is possible/works.
Thanks in advance!
Thanks in advance!
