Sanden compressor plug leak
Posted: Fri Sep 05, 2025 2:30 pm
What size O-ring should be used on an oil filler plug? My local shop tech says there is a leak there.
https://mail.autoacforum.com/
Once the refrigerant has been recovered, simply unscrew the plug and match up with a new green NBR O-ring. O-ring seal plugs and fittings should not be overtightened.msrichmond wrote: Fri Sep 05, 2025 2:30 pm What size O-ring should be used on an oil filler plug? My local shop tech says there is a leak there.
