High hi side pressure 400psi
Posted: Sat Jun 21, 2025 1:15 pm
I have a 2009 Nissan rogue that is blowing hot.
I put the gauges on and I'm seeing a high side pressure of 400psi and a low side pressure of 70psi. When the engine is off, I don't see the low and high pressures equalizing either.
I'm pretty sure the compressor is not coming on probably due to the high side excessive pressure. It's a bit hard to see the compressor down on the bottom of the engine but I don't think the clutch is engaging.
The condensor itself looks ok. The driver side fan is on and blowing at full speed as far as I can tell.
I use to do some auto a/c diy work years ago on a few cars, but it's been awhile.
I assume this car is using r134a as far as I know. I don't know whether the a/c system has been serviced before.
I have to assume this is probably a blockage due to a sticky expansion valve or a bad dryer that is clogged or come apart. Is that a reasonable assumption? Next steps would be to evacuate and flush the system, probably replace the dryer, exp valve and maybe condenser at a minimum?
What do you all think?
If I do replace those 3 components, do you recommend attempting to flush the evap core? What do you use for that?
If I find evidence of a disintegrated dryer with dessicant in other parts, is it recommended to replace the compressor also?
Thanks in advance
Thanks in advance
