STRANGE ISSUE NEED HELP!
Posted: Thu Jun 19, 2025 6:00 am
Hello there, I'm new to this forum and I'm here cause I need some guidance from those who are smarter or more knowledgeable than me. I rarely run into something I can't figure out on my own but this one kinda has me stumped and in this case I'm neither afraid or ashamed to ask for help!
The issue at hand is that I have a customer with a 2016 Tahoe that is blowing warm air in the front and semi cool air in the rear. About 2 years ago on the same vehicle I replaced the compressor, condenser, drier, and both front and rear TXV's. Also did a full system flush and replaced all the orings on the system at that time. I did all this because he had a bad leak at the compressor and I got all the above listed parts with the flush, oil, and refridgerant in one complete kit.
Fast forward to today. His system has been working flawlessly and blowing ice cold up until earlier this week. I hooked my gauges up and pressures were about spot on where they should have been for an 87 degree day. 45-50 on the low, pretty steady 200 on the high. Water is dripping like crazy from the condensate drain which tells me that the Evaporator must getting pretty cold however the suction line coming out of the firewall feels warm which has me a bit puzzled. Also on my scan tool, the evaporator core temperature was showing 87 degrees which matched ambient air temp and again has me puzzled....Why is it condensating and dripping so much if its 87 degrees? The blend doors appear to be functioning because I can cycle from hot to cold no problem and I can see on the scan tool that the "desired" and "actual" blend door positions match so I've ruled those out as being the culprit. What could be going on here? Pressures good, dripping like crazy from the condensate drain, blend doors functioning, but no cold air and the suction is warm. Rear blows cool but not cold.....IM STUMPED!
