Page 1 of 4
1998 Frontier (288K miles)
Posted: Wed Jun 11, 2025 6:46 am
I've been lending my white 1998 Frontier (288K miles) to my daughter and son-in-law. Apparently 2 weeks ago when it rained in Phx, he tried to rotate the air controller to "defrost" position, and something broke. It turns out that in the approximately 10 years Kori returned the Frontier to us that we'd never rotated that knob to either "defrost" or to "heater" positions, just let hot air come right at us when we did use heat. So it broke with all the air coming out the windshield vents, the defrost position, couldn't adjust; that just doesn't suit as one NEEDS the AC in Phoenix AZ.
Anyway, on the 1998 Frontier the vent flaps are controlled by cables, and mechanism on the driver side of the air control box in middle of the dash, see diagram/photo.
I took at look at this today; first thing I did was to spray some cleaner/lube over the mechanism. Then I had to remove several dash and trim parts. The Haynes manual I have was actually considerably better for trim parts removal than the official factory service manual I have downloaded. Anyway, the mount for the cable sheath had broken loose, because the mechanism had gotten dirty and gummed up over the past 27 years. I cannot fathom anyone would go under the dash to try to clean and lube that every few years. Anyway, after getting enough access, I somehow freed up the mechanism and then used trial and error to get the air coming out the main vents only to driver and passenger, figured we didn't need under-dash or windshield air flow, as long as the AC worked, and heated air come come out the same vents. This took 2 hours, but was under the carport.
So after buttoning that up, I replaced the engine throttle position sensor with a new one, the correct part. And then had to turn off the air bag flashing light (I'd unplugged the harness passenger on-off connector to remove that trim piece). This part took another hour. It was only 109F in Phx today, now back up north now.
Re: 1998 Frontier (288K miles)
Posted: Tue Jul 29, 2025 12:03 pm
Same 1998 Frontier, and I'm still "fighting" a slow refrigerant leak. Fortunately, this vehicle is an "extra" vehicle but I'll want to address this by fall.
I added 12 oz R134a in 2024, and another in Feb. 2025. The system has dye in it because I added some when I replaced the high pressure line in mid-2017 (pinhole leak). I have UV light/goggles and an electronic leak detector and bubble solution, and I just cannot find the leak. The compressor is still engaging but lines at firewall just ain't what they should be, so I didn't even attach the service gauges this time.
Once it cools down in September/October, plan will be to add 12 oz R134a and look for dye leakage with UV light in dark garage. I'll also take off the AC belt and try the sniffer with "the old storage bag around the compressor" trick and also check the evaporator case drain lines again. I did have a cracked low side cap a few years ago and lost some refrigerant, so I'll re-check that schraeder and replace if necessary. Even though I did buy pure R134a at store closeout for $6 a can, I'd rather find the leak and fix it right. Even if I need a brand-new compressor, I'm OK with that, I just don't want to throw parts at it without confirmation.
Posted: Wed Jul 30, 2025 9:46 am
Cusser, you've probably already done these things, but have you "sniffed" all around the compressor seams? Also, have you checked along the bottom of the condenser, the top of the R/D where the lines attach, the inlet/outlet TXV connections, any metal lines down low (especially those having foam insulation, which could hide oil and refrigerant leaks), the dash vents, and the condensate drains?
If you have and still turn-up nothing, I think I would replace all the accessible o-rings under the hood, giving each one a light coat of Nylog Blue before buttoning-up everything. I'm presuming that the system is empty of refrigerant right now.
Posted: Wed Jul 30, 2025 9:59 am
Let's not forget the O-rings on the TXV valve inside the case.
https://www.ackits.com/evap-nissan-fron ... ch=59-0011
Posted: Wed Jul 30, 2025 11:44 am
Tim wrote: Wed Jul 30, 2025 9:59 am
Good point, if I detect a leak in the evaporator core through vents or condensate tube.
If I do determine where the leak really is, I'll post here before I order the spare parts from you.
I also have a 2004 Frontier with same engine and AC, and that compressor seized at 103K back in 2018, so I have hands-on with compressor, condenser, drier replacement and line flush....
Posted: Thu Jul 31, 2025 5:50 pm
JohnHere wrote: Wed Jul 30, 2025 9:46 am
Those are great ideas John. My plan will be to run the system a couple of minutes, then check the service valve caps with sniffer first, and then bubble solution, because I would expect some UV dye there anyway due to attaching service valves in the past. Only after that will I attach my service gauges; i my high pressure reads too low, I'll add another 12 oz. of Pure R134a. I'll pull it into my garage where it can be dark, take off the bottom engine protector plate, and start with UV light/goggles and sniffer. From underneath I can better access the seams in the compressor.
Past investigations (February 2025) did not show any leaks at the replaced high side line fitting at the compressor, or any coming out the air vents into the cabin, but that will be re-investigated. One issue is I don't feel like driving down 100 miles and working in my hot garage while the projected temperatures in Phoenix are 112-117 for the next 10 days !
I last added UV dye in 2017 - I shouldn't need to add more, right?
Posted: Thu Jul 31, 2025 8:41 pm
UV dye seems to last a long time. Since the system has had some leakage over time, you might consider injecting another half ounce or so just to be sure.
I know Phoenix very well. Mrs. JohnHere and I began visiting the area in 1972 when Fountain Hills was just a man-made lake, a water feature, and three model homes. Some other friends of ours live in Prescott Valley, and my sister and her husband live in Surprise...and before that, in Anthem. And whenever we're there, we're sure to visit Ben Avery at least a few times.
Posted: Mon Aug 11, 2025 5:36 pm
Well, call me Gomer.
I checked the service valve caps first with sniffer, no leakage there. I attached the service gauges and ran the AC for a couple of minutes, then took off the bottom engine plate and checked all around for leaks using both UV light/goggles (I really need a new UV light, but it showed dye at the low side service valve. As was recommended here, I checked the underside of the compressor, the seams, the line connections, and even at the AC clutch drive plate: nothing, used both sniffer and UV light. Nothing at the drier, the connections at the firewall, nothing at the condensate drain, nothing out air vents using sniffer. I checked crimps on the rubber lines, no leak detected or residue. The bottom of the compressor looks a little gunky, but at this mileage there is some engine oil mist/splatter.
So channeling Gomer, I added 10 oz. R134a and low side was 30 and high side was 260 psi, at 111F ambient. I took it for a short ride and vent temperatures got into the high 40s.
If I knew the compressor or condenser was leaking, I'd install new. I'm not throwing a new evaporator or TXV at it without confirming such leak there....
Posted: Fri Sep 12, 2025 7:01 pm
Update:
I purchased a new/better UV light and goggles, and got down to Phoenix to take a look. The Frontier appears to have significant dye on the top of the AC compressor. I had replaced the high-pressure line in 2017 with the only available one, which had compressor fitting 5.5mm longer than the factory one, but the O-ring groove was in the right place, so I cut down the new one to match.
So I think that next time the refrigerant level drops, I'll replace O-rings on the high side and even do the factory O-ring on the low side fitting.
No, I did not get a sniffer reading of a leak there.
Posted: Sat Sep 13, 2025 7:09 am
If you can fit it over the pipe and still connect, try a same-size captured o-ring.
