Clutch slips after engine warms up
Posted: Wed Apr 30, 2025 5:36 pm
AC blows cold at start up, after running for about 5 minutes the compressor seems to be slipping on the clutch.
Automotive AC Repair and Discussion topics.
https://mail.autoacforum.com/
How much mileage has this vehicle logged?GMBDguy wrote: Thu May 01, 2025 12:01 am I dont have the car in front of me at the moment. But immediately before the issue they were within range while running, AC on. What I recall is like 40-50 low side and around 190ish high side. 75-80 degrees out.
It's very hard to tell whether a TXV is stuck (shut?). Normally, a TXV throttles the refrigerant and never actually closes completely. Usually, a vacuum reading on the low side means that the TXV is restricted by something, like desiccant beads from a defective receiver/dryer (R/D).GMBDguy wrote: Thu May 01, 2025 12:01 am Vehicle is an 09 grand cherokee. With a kind of unknown AC past. The owner knows basically nothing about cars. He says the compressor was replaced a few years ago but AC never worked before or after, unknown as to why. First thing I noticed was the fuse was missing. Then I hooked up the gauges and it was pulling a vacuum on the low side. Took it all apart and found a stuck expansion valve, otherwise everything was spotless, but there was UV dye in it.
What did the flushing chemical look like when it came out the first time? Black or semi-clear? Any "glitter" (metallic particles) or plastic bits in it or in the compressor oil?GMBDguy wrote: Thu May 01, 2025 12:01 am I still flushed it all out because who knows who worked on it or what they did. I flushed the lines, evap and condenser with AC system flush and let the compressor drip with the inlet/outlet holes facing down. I also blew the compressor out with shop air but did not use the AC flush on it. I blew out the parts I flushed with compressed air and replaced the expansion valve and dryer with new parts. The sticker on the car says 150cc (approx. 5oz) of PAG46, four seasons says 4.4oz. I put in about 4 ounces of oil, to account for any residual.
A few thoughts: Did you change the vacuum pump oil before evacuating the system? If not, the oil might have been contaminated with debris and moisture, which in turn could be why you didn't see a vacuum below about 28 InHg, even after five hours. Another factor is your location above sea level. The more elevation, the less vacuum that's possible.GMBDguy wrote: Thu May 01, 2025 12:01 am Pulled a vacuum on the system and it held overnight. Then I ran the vacuum pump for about 5 hours. I dont know if its my gauges or the pump but it never pulled more than about -28... never has (gauges sit at just slightly above zero not hooked up).
212,000 miles
I could be entirely wrong on that number. It was getting late and I did not write anything down.If your recollection is correct, and with a low side of 40-50 PSI, the evaporator temperature will be at least 45°F and even higher, much too warm for any measurable cooling. The high side at around 190 PSI is about right for a 75-80°F ambient temperature, though.
I removed the TXV and attempted to blow through the metered small port and could not get any air flow at room temperature. I then dissambled the TXV and the pin was stuck shut. I could turn the TXV upside down and the pin would not fall free. After sitting on the bench a few days I took it apart again and it did fall free. Whether this was a previous issue before I got my hands on the car I do not knowIt's very hard to tell whether a TXV is stuck (shut?). Normally, a TXV throttles the refrigerant and never actually closes completely. Usually, a vacuum reading on the low side means that the TXV is restricted by something, like desiccant beads from a defective receiver/dryer (R/D).
TWhat did the flushing chemical look like when it came out the first time? Black or semi-clear? Any "glitter" (metallic particles) or plastic bits in it or in the compressor oil?
Since you flushed-out all the components and let the compressor drain out, I would have installed the full amount of PAG oil, 150cc (or 5.3 fluid ounces). Right now, I would guess that the system is about 1.3 fluid ounces short (not good for a system that holds only 5.3 fluid ounces) given that you installed about 4 fluid ounces of PAG. Incidentally, the under-hood decal always takes precedence over any other specifications, including those from Four Seasons.
Since we don't know the A/C repair history of the vehicle—and we also don't know whether the formerly replaced compressor was a rebuilt or new unit—I would have replaced the compressor with a new one, along with the condenser, which generally can't be effectively flushed, as well as the TXV and R/D, which you did. But IMHO, you completed only half the job by not replacing the compressor and condenser.
The vacuum oil was not replaced but was clean in the sight lense. I have only used this vacuum pump one other time, a few years ago.A few thoughts: Did you change the vacuum pump oil before evacuating the system? If not, the oil might have been contaminated with debris and moisture, which in turn could be why you didn't see a vacuum below about 28 InHg, even after five hours. Another factor is your location above sea level. The more elevation, the less vacuum that's possible.
In addition, you'll need to "zero" your gauges. Do this with the gauges disconnected from anything and the hoses off. Remove the soft white plugs in the face of the lenses, insert an appropriately sized screwdriver through the lenses, engage the adjusting screws, and rotate the screws until each gauge reads precisely "0". Replace the plugs.
Or even better than a Manifold Gauge Set (MGS), use a micron gauge and ensure that it reads +/- 500 microns when you're done evacuating the system, again depending on your elevation.
I think I am going to zero the gauges. Re-evacuate the system. Double check for leaks. Pull a vacuum again for a couple hours and try this all over again. Now I am questioning how much refrigerant is in the system, since I have reconnected the gauges a couple times and I may have forgotten to purge the lines one time that I did it.From the MGS readings in your video, it appears that the system is low on refrigerant, which must be weighed-in for accuracy. The slipping clutch might be a byproduct of a low charge, bad compressor, clogged condenser, etc. The small cans probably don't have exactly 12 ounces net weight in them. In fact, I know they don't.
I would. Even though the cap is the "real" seal.GMBDguy wrote: Mon May 05, 2025 9:30 pm Should I just always replace the schrader valves on older systems while empty? Seems like its cheap insurance.
