adding dye for top-up?
Posted: Sun Feb 09, 2025 10:24 am
I have a DIY new system with about a 1000 miles on it. It works, thanks to help here but I'm refining it this winter by rotating the compressor 90 degrees to get hoses away from the exhaust manifold. It's a Sanden compressor with the "V" fittings.
I had the system evacuated at a shop ($56... very reasonable!). 28 oz of refrigerant and 1.5 oz of oil got pulled out.
The tech suggested adding dye before I put everything back together.
My question is: can I put in the small bottle of dye to make up for the 1.5 oz of oil removed into the oil filler hole on the compressor?
p.s. I did order a new receiver/dryer.
