Ford Compressor/Head Gasket Repair
Posted: Fri Oct 11, 2024 12:42 pm
I have a1966 Ford with the Name Plate as follows:
FORD No. Y240178 G
PT. C35A-2875-B
R-12 036
I did the "magnet test" and the case seems to be aluminum, but the head bolts are steel. I'm trying to bring the system back to life but it will not hold a vacuum.
I did all the basic tests for finding the leak with no results. I decided to run a can of UV die through the system. The low side pressure went to 90, still nothing visible with the UV light. Today I put the light on the system and there's UV die leaking around the cylinder head gasket area.
My questions are- what brand is this compressor with regard to obtaining a replacement Head Gasket ( I have not seen anything for Ford) and can I do this repair with the compressor still mounted in the engine bay?
One more question, did the pressure go to 90 possibly because of a blocked condenser and/or R/D? Yes, I have a new condenser and R/D standing by to be installed. Thanks, looking forward to any additional tips or suggestions.
FORD No. Y240178 G
PT. C35A-2875-B
R-12 036
