Problems with a Honda Civic 2011.
Posted: Mon Sep 23, 2024 1:52 pm
In a previous post I was asking for help deciding if it would be a good idea to replace the condenser of a Honda Civic 2011.
So I changed the condenser and added 50ml or 1.7oz of PAG46 oil in the larger hose of the condenser just as the service manual says, I felt that it was too much oil, but I decided to do what the manual says.
I pulled vacuum for about 40 minutes, and let it stayed all night, in the morning it was fine, I let it sit through the day, but at night the system loosed a little bit o vacuum, so I turn on the pump another 40 minutes, and let it sit all night, and in the morning it was the same level.
So this morning I started to charge my system with r134, but I had 3 problems:
- It was taking forever, even with the method of putting the can in warm water.
- The high side pressure never passed above 140psi, and the low side took forever to come down after every time I open the gauge to charge more gas, it goes up to 120psi when I open the valve, and slowly reached 30psi after a couple of minutes.
- Condenser was almost cold to the touch, and vent temp was not cold.
It feels like something inside the system isn't allowing the refrigerant to go inside and to build up pressure, I don't know a lot about the theory and physics behind AC, I'm just a DIYer.
So, maybe I added too much oil?, or maybe insufficient vacuum? because I've been having problems with my pump, it feels like it has a small leak. If it is the oil, how do you remove oil draining the compressor?
But the bigger problem is that is my wife car, so I'm gonna be in big trouble if I'm not able to fix it hahaha.
Update: I just realized that the manual says civic 2006-2008, so I guess that even though the 2011 is the same 8th gen, it should use a different amount of oil, but I'm not sure.
