Adding oil to system that was flushed and new compressor installed
Posted: Thu Sep 19, 2024 6:41 am
Greetings!
In an earlier post I got good info here on my project re-doing the A/C in our grocery getter Chevy Aveo with high miles. We rounded up a new condenser, expansion valve and new (not rebuilt) compressor. We flushed out the lines which were nice and clear beforehand, and checked the suction screen on our existing compressor for debris and it was nice and clean.
I am a bit confused with the instructions that came with the new compressor from Advance Auto Parts, as it states the compressor is pre-filled with oil and do not drain. It then went on to say add the appropriate amount of oil to the compressor and system as per manufacturers specs. Wouldn't this cause the system to have too much oil in it? The entire system oil capacity is 6.8 oz.
I'm suspecting the instructions are wrong, and I should drain the new compressor of whatever amount of oil is in it and simply add the proper 6.8 oz, splitting the amount between the compressor and evaporator. Would I be correct in doing that?
Thanks for any help!
Fred in St. Pete Florida
