Next Step: Clean/Replace Expansion Valve?
Posted: Fri Sep 13, 2024 11:45 am
Once again I come here to the experts before I make more mistakes...
Long story short, I had a compressor that seemed to go out as I heard new belt squeal and it had difficulty turning. I flush the system using two quarts of flush and shop air, disconnecting the evap and cond and hoses and flushed them in the opposite direction of flow. Then I replace the compressor, a Sanden SD508, drain the oil out of the new compressor and fill the compressor with the correct amount of oil, replaced the receiver dryer, I pull a vacuum for an hour and it appears to hold it overnight.
Next day I attempt to start filling it. It takes the first can of 134a. Low side started to creep up and got to where it was below 30 pounds pressure while high side rose to about about 100. I start the second can of 134 and the low side dropped below 5 pounds, while high side stays at 100. It does not seem to suck any 134 in? I shut the engine and both sides equalize to about 50 pounds. Start engine again and I cannot get any 134 into the system. Yes, the valve on the low side of the gauge was opened.
I stop there. I am wondering if my orifice tube caught a piece of garbage and is blocking the system? Can this be taken apart and cleaned out? If so how does it come apart?
Or what else might be likely to cause the system not to accept the second can of refrigerant?
Thank you for your advice in advance!
