A/C not cold when hot @ idle... Tried Everything!
Posted: Thu Aug 01, 2024 12:16 pm
2007 Honda Odyssey EX-L
145K
Ever since I purchased this vehicle about 6 months ago I can not get the A/C to blow cold when it's hot outside while idling...
I Live in central Florida and as you can imagine it's SUPER hot this time of year. I do construction and sit in my vehicle during the lunch. I currently need to try and find some shade to park under to have any hopes on getting some cold A/C.
While driving or at night at Idle, the A/C blows super cold around 45° or lower.
But during the day parked in the sun @ idle the A/C is blowing at only 70° - 75°... If parked in the shade it blows slightly cooler but not much.
***** WHAT I'VE DONE SO FAR *****
Last week I had the system evacuated, and I connecting my vacuum pump and let it pump for a good hour. Then let the system sit for an hour to ensure I had no leaks. I then added exactly 725 grams of R-134a using a kitchen scale, and according to the my manifold gauges the pressures were spot on! (Service manual shows the vechile needs between 700g - 750g of R-134a)
I also confirmed that my electric fans are on while the system is calling for A/C. The only other thing I could think of was checking the condenser to make sure it wasn't clogged or the fins were all bent. But after thoroughly checking, the condenser coil looks great...
So I'm currently at a loss of what's going on. As I mentioned the A/C blows super cold while driving or at idle when the sun is down!
Does anyone have any ideas what could be goin on? I've also noticed that if I do not have the recirculating turned on AC blows substantially warmer all the time.
145K
