Recovery vs. reading the gauges?
Posted: Wed Apr 19, 2017 12:17 pm
I'm a DIY'er on my car (2004 Mazda 3) for most things. I've got a set of gauges (converted from R-12: thoroughly flushed; R-134 quick connects added) and can taps, etc. I don't own a pump or other accessories so can't do a replacement, only add as needed, trace leaks, etc.
The AC will put out only about 50 degrees air on a not-so-hot day (70). My local AC shop said that the only way to treat this is to remove the R134 and weigh(?) it. Then replace the specified amount.
What happened to reading gauges? My rudimentary understanding of troubleshooting is that by reading the pressures and knowing the temperatures, you can determine whether the system is under- or over-charged, and other mechanical issues (compressor, valve, blockage, etc.)
I agree that the only way to know--absolutely--if the correct amount of refrig. is in the system is to recover/recharge, shouldn't a competent tech be able to also determine this by use of gauges?
Thanks.
Thanks.
