2006 Mazda 3 AC not cool enough after compressor kit replacement
Posted: Sun Jul 07, 2024 6:35 pm
Hello All,
New member on this site and I am hoping you can give me some help on a perplexing problem. I've worked on cars for decades but am a little new to A/C work. A while ago on my 2006 Mazda 3 A/T, the A/C compressor locked up and I replaced it with a UAC kit (compressor, condenser, drier and expansion valve). I have the Mazda Service Manual and I replaced the components as dictated by the procedures in the manual. A/C lines were flushed and blown dry, new seals installed, AC oil came in the correct amount in the new compressor, and system evacuated to 28mmHG and charged to 24PSI Low, 250PSI High (near 100F degree temps) at 1500 RPM. As far as I can tell the 22PSI is about 95F degrees per the manual and I was definitely hotter than that. Hard to read the graph in the manual, but graph goes higher than 22 at near 100F degree temps.
I do not have a scale or any other way to measure the refrigerant charge. I assume that, if a system had the adequate refrigerant amount within its specifications, it would be able to attain the proper pressures in the proper ranges. I.E. proper pressures= proper refrigerant charge…
Problem is, I can only get about 70F degrees at the AC ventilation ports with MAX Fan. All temps taken while car is in the driveway running at 1500RPM (Service Manual spec), 100F ambient temp, with the radiator fan running. Driving it, I can get the AC vent temp down to about 65, but no more.
I am thinking that one of the new components is faulty and leaning towards either the compressor or expansion valve. Or a second theory that I’ve picked upon this site is that if a system has the proper refrigerant charge by weight, and the pressure are off then there is an issue somewhere? If so, what could potentially be the culprit?
Anyone experience something like this or have an idea of where to look for the issue?
Thanks in advance.
Thanks in advance.
