Compressor oil 2005 Toyota Prius
Posted: Fri Jul 05, 2024 12:37 pm
by Artieb
Hi, I have drained my used compressor, and got 10 ml from the plug. Almost no oil from the inlet or outlet. Is the nd11 oil from the plug the same oil that inlet and outlet? Do I really want to put oil in the inlet or outlet?
Re: Compressor oil 2005 Toyota Prius
Posted: Fri Jul 05, 2024 3:22 pm
Toyota gives the following formula for refrigerant oil replacement:
Standard: Oil capacity inside new electric inverter compressor (100 + 15 ML ) - Remaining oil amount in removed compressor assy = Oil amount to be removed before installation
