2006 Jeep liberty Crd low pressure switch
Posted: Sun Jun 30, 2024 12:13 am
Ac stopped working a while back, prematurely changed compressor but it didn’t fix problem as the clutch wouldn’t even engage. Fast forward now did some troubleshooting and found compressor works good when I jump pins at low pressure connector. Air blows cold. Thought this meant bad low pressure switch so went to buy new one, installed and now I have an intermittent compressor it’ll turn off and on. Was hoping maybe they gave me a defective sensor so went to buy a separate one different store but same result. Jumped pins at connector again to double check and yep engaged compressor and blows cold air. Filled up with Freon just in case the charge was low, I’m pretty stumped because jumping the pins and it working usually is a guarantee that sensor is bad. Maybe I should replace accumulator? I’ve changed the compressor twice now and never changed accumulator I know this is really dumb of me but yea.
