1997 Chrysler Sebring LX Coupe – Not Cool
Posted: Fri Jun 14, 2024 7:02 pm
Hi everyone,
I have a 1997 Chrysler Sebring LX Coupe 2.5L V6 with 105k miles. The engine is Mitsubishi and the transmission is Chrysler, everything else is almost identical to a 1997 Mitsubishi Eclipse. 4 years ago, at ~94k miles, I replaced the a/c compressor, condenser, receiver/drier, expansion valve, and evaporator: all new parts. I evacuated the system and waited the requisite time to ensure a vacuum was retained, and added the exact grams of 134a refrigerant as per Chrysler shop manual specifications. The high and low side pressures at ambient temperatures were very close to correct as per shop manual specs. Interior discharge air-vent temp was ~45 degrees in Miami 95 F -degree summer.
I just started using the car again after it sat for the past 18 months and the a/c barely cooled. I tested the system pressures as per shop manual at 98 degrees in the shade. Low side tested at ~80psi at 2k rpm with high side at 110psi. At ~4k rpm the low side dropped to ~45psi and the high-side remained at 110psi. Shop manual list pressures at 95 F degrees ambient temp at 30psi low-side and 206psi high-side at 1k rpm. Lines going into and coming from the condenser registered at ~115 degrees using a Klein Tool infrared thermometer as did the lines from and to the evaporator. Any help would be greatly appreciated.
Thanks!
Thanks!
