Noise after AC service
Posted: Sat May 11, 2024 9:21 am
Hello,
My name is Felix from Frankfurt/Germany, new to this forum. Hope you are all doing well. I registered to get some help with the AC system in my car. The car is a 1989 Chevrolet Caprice Classic LS Brougham, 45k miles, stock 305 TBI.
Background info:
-preowner converted the AC in 2021 from R-12 to R-134A since it is absolutely impossible to get R-12 in Germany and they can send you to jail if you still charge a system with it (according to his info, the system was flushed, new accumulator, new oil, new o-rings and the evacuation and refill was done by a professional AC machine)
-AC was cooling nice, however the (probably original) refrigerant high-pressure rubber line from the compressor to the condenser had like a thumb big bubble on the outside, so basically short before bursting
-I managed to get new R-134A refrigerant lines in time without the line bursting and had the shop install it. The accumulator and orifice tube (original fixed GM orifice tube) were replaced at the same time plus every o-ring and gasket that was touched
-original charge of R-12 according to the sticker is 3.5lbs. Since we didn´t know how much the shop of the preowner charged and if and how much the hose leaked, I trusted on the mechanics experience. He drives some GM trucks from the late 80s with basically the same engine and AC system and the system was charged with 3.3lbs R-134A. This was done about 1 year ago in 2023.
-compressor (GM R4), condenser and evaporator are original
-mechanical fan only as original, but I replaced the fan clutch since the old one was always engaged
After the repair, the AC was ice-cold, but at a stoplight or very slow driving, I can hear the refrigerant inside the cab. The noise goes away with faster driving but once the car idles, the noise begins to appear louder and louder, like water rushing through a pipe and disappears when continuing to drive. The hotter it is outside, the louder the noise is at idle. Before the repair, no noises were heard.
If it is very hot outside (around 95°F), the AC feels weak at idle but gets cooler as soon as I drive. On a normal warm spring day like today (77°F), there is no real difference between idle and driving, it gets cold inside the cab to the point where I have to turn the heater on a bit. I thought the noise is coming from the new orifice tube that lets more refrigerant flow. The old one had some black debris on it (not totally clogged, just a bit dirt) but the mechanic said it looks like the original part, so it is kinda normal after 35 years.
Took the car to the shop, mechanic said it can be two things:
-weak compressor that does not generate enough pressure at idle
-not enough cooling at the condenser when its hot, so the refrigerant does not condense completely and gas is rushing through the evaporator
Both ways will be an expensive fix, since I have to order everything from the USA. Price until the part gets here with shipping and tax is basically double the price on Rockauto.
Is this normal behaviour for those kind of ACs or can I trust the mechanics opinion and let him do whatever it needs? New compressor or upgrades for airflow and a modern condenser..
Unfortunately I cannot measure the pressures myself right now, I don´t have gauges yet and most German shops won´t touch american cars, just because they are american and they can´t get any documentation on them, so I have to wait for my shop to have a free appointment (he does 95% US classic cars and the next free appointment is like in 2 or 3 months).
Maybe some of the pros here have heard of that symptom and give me an advice on how to go on.
Thanks and all of you have a nice weekend!
Background info:
