Lots of oil in gauge manifold after vacuum and charge - 98 explorer
Posted: Mon Jul 18, 2016 6:02 pm
I just replaced the compressor, accumulator, and orifice tube in my 1998 Explorer. Everything went very well up until it came time to recharge. I couldn't seem to pull vacuum past 24 in Hg. After much troubleshooting, using 3 different vacuum pumps, I found out that being at 5300 ft of elevation would reduce my gauge reading by about 5 in Hg. So I figured I had pulled adequate vacuum, but just to be sure I drove around until the car got nice and hot, ran the heater to heat up the evaporator, then put it back on the vacuum pump for an hour to be sure all the moisture had boiled off. That was probably overkill, and probably what led to my problem.
The first indication of a problem was a bit of oil frothing out when I purged the fill line of air. Didn't think too much of it and proceeded to fill the system with the required 28oz of refrigerant. Air was blowing nice and cold, and the pressures looked good, so I started to pack it in. This is when the issue became apparent.
After unhooking the manifold gauges, I went to purge the refrigerant remaining in the manifold lines. No problem with the low side, but as I started to release the high side, me and my engine bay got a frothy oil shower. I'm not sure how to describe or quantify how much oil came out, but it was a significant and surprising amount. I immediately re-closed the valve, so there is still about 100 psi and what I assume to be a lot of oil in the high side line.
FYI, I put 5oz of PAG 46 in the suction port of the new compressor and gave it a few turns by hand before installing.
Any ideas of what happened here and how to proceed? Did I really vacuum up that much oil, or did something else happen?
I am thinking I need to somehow capture and measure how much oil is in the high side hose, or else try to force that oil back into the system so that I have the proper amount of oil in the system. Thoughts on the best way to go about this?
Looking forward to the replies. Thanks!
