03 Jeep Wrangler 500PSI+ high side pressure
Posted: Sun Apr 07, 2024 1:00 pm
I've got an 03 Wrangler with the 2.4L 4 cylinder. Last summer the AC was working fine. Very recently I noticed that I no longer get cold air through the vents so I plugged in some gauges.
With the engine cold starting on a 60F day, when I turn the AC on the high side immediately climbs to 500 psi and then the compressor clutch disengages.
I don't think it's an issue of airflow overr the condenser I don't get any cold air while driving even when it's not that hot out (around 60F).
The condenser itself looks ok, no very damaged fins (the car does have 180k mi on it so there's a few bent fins here and there). Could there be a blockage in the system somewhere?
