How many amps does a FS10 clutch need, and polarity?
Posted: Mon Oct 16, 2023 5:51 pm
				Want to make sure I wire enough capacity for the clutch.
Just got the pigtail for the FS10 compressor. The wire is 2.08mm which is 14AWG, that's like 12-14A. The last compressor used a really thin clutch activation wire like a 20?AWG
Also, research indicates the 2 wires one is + and one - (ground). The last compressor used just a + trigger wire. Please confirm that it needs both a + and -.
Also2, any polarity on the clutch wiring? I wouldn't think so on a clutch but a couple of the Ford discussion forums mentioned the side by the release tab should be +. Please comment.
Andy
Andy
