bohica2xo wrote: Thu Oct 12, 2023 1:33 pm
Given the very large evaporator you are using, the line lengths and large receiver in your system, I would treat it the same as an Expedition or Excursion using the same FS10 compressor with Rear A/C.
Expedition:
1997 All Eng.; w/ Rear AC – 13.00 Oz. PAG-46; 62.00 Oz. R-134a
Excursion:
All Eng.; w/ Rear AC – 68.00 Oz. R-134a; 14.00 Oz. PAG-46
E350 Van
2002 8 Cyl. 5.4 Eng.; w/ Rear AC – 13.00 Oz. PAG-46; 46.00 Oz. R-134a
So 13 to 14 ounces total.
Put the extra oil in the receiver or the liquid line.
Thanks bohica2xo for that info, seems in line with MACS article (below) and there are still some outstanding questions.
These are the ratios for the model information provided
Model / oil oz / R134a oz / oil ratio
Expedition 13 62 21%
Excursion 14 68 21%
E350 Van 13 46 28%
Thoughts on the following?
1) Conflicting oil ratio %. See Sanden vs MACS conflicting references below
2) Calculated oil requirement based on 25% rule:
Figuring out Refrigerant capacity (please check my math below)
Item / refrigerant oz / oil oz@25%
Hoses 11.10 2.77
Receiver/drier(2”x7”tall - typical) 7.94 1.98
Receiver/drier(4”x7”tall - large) 31.74 7.94
PF Condenser?
Evaporator?
Compressor? (shipped with 3oz)
With “typical” drier about 5oz oil so far on 19oz of R134a
With “large” drier about 11oz oil so far on 43oz of R134a
for the receiver/drier I estimated R134a liquid capacity at 60% of volume to account for desiccant/pipes/etc.
Andy
***Oil % differences references
Oil ratio Sanden 3.3%-8% vs MACS article “the 25% rule” which corresponds to the info given by bohica2xo. The MACS article seems to take many different compressors as a whole.
- Sanden Service Guide 3.3%-8%
“The Sanden SD series compressor achieves optimal durability and cooling performance when oil circulates through the system at a ratio of 3.3% to 8% oil to refrigerant.”
- MACS Article 2018 - THE 25% RULE "Our struggle with oil"
Pg 24
https://www.macsw.org/WEB/images/Macs_D ... i42MC4wLjA
Pg 28/29
THE 25% RULE
For a long time, we used a rule of thumb that basically said that the oil charge amount is generally around 25% of the total refrigerant charge amount. For example, if you’re working on a 2011 Kia Sedona (with a 3.5L V6), the specs say it takes 900±25cc (about 31 ounces) of R-134a and 210±10cc (about 7.25 ounces) of FD46XG PAG oil. Do the math, and you come up with about 23% (try this on a few more vehicles, and you’ll get similar results).
Figure 5: Many vehicles from the last 10 years are using oil separators, which result in greatly reduced oil charge amounts in some systems. Pay close attention if one of these shows up in your bay. Models from just a few years ago may have required double the amount of oil. Even though the number may not look right, it probably is, and adding too much oil can be detrimental to the system.
***refrigerant/oil calculations
- RedDot Refrigerant guide 2009
https://www.btrac.com/documents/refrigerant-guide.pdf
AC systems with LESS THAN 3.5lbs(56oz/4.66-12oz cans) of R134a
5 cyl or less:
[R134a(lbs)*2]+1.35=total Oil Charge (oz)
7 cyl or more:
[R134a(lbs)*1.07]+2.4=total Oil Charge (oz)
AC systems with MORE THAN 3.5lbs(56oz/4.66-12oz cans) of R134a – On Vehicle Testing Recommended.
*At 3.5lbs the calculation above yields 8.35oz oil. Likely not fully accurate with longer hoses and larger receiver/drier
- Refrigerant calculations
Hose Refrigerant and oil
Type Size lb/ft oz/ft ft Total lbs Total oz Oil @25%
HPV 8 0.0043 0.0688 15 0.0645 1.032 0.258
HPL 6 0.0346 0.5536 18 0.6228 9.9648 2.4912
LPV 10 0.0011 0.0176 6 0.0066 0.1056 0.0264
Totals 39 0.6939 11.1024 2.7756
R134a OZ/cubic inch From RedDot document
5/16 ID
5 Numerator
16 denominator
0.3125 Diameter
0.15625 radius
12 in tall
0.92039 ci/ft
0.0346 lbs/ft From RedDot document
0.03759276 lbs/ci
0.601484153 oz/ci of R134a
Large
drier
7 h
4 d
87.96 ci
60% liquid volume (less dessicant etc)
52.776 ci liquid refridgerant
31.74 oz refridgerant
25% oil ratio
7.94 oz oil
Small
drier
7 h
2 d
22 ci
13.2 ci liquid refridgerant
7.94 oz refridgerant
25% oil ratio
1.98 oz oil
