Does air get in system when using AC manifold gauges?
Posted: Wed Oct 04, 2023 3:31 pm
Like the thread title says, do you have to worry about introducing air into the system when connecting the AC manifold gauges in order to check pressures?
I realize that the AC system is under high pressure, and even the low side will be way higher than atmospheric pressure, so I would imagine that the refrigerant simply 'pushes' up against the air in the AC MGS hoses and keeps it from actually being sucked into the system. However, I also started to wonder if maybe the air in the low-side "blue" hose might get sucked into the system when the engine/compressor RPM goes up and the low-side pressure suddently drops (like, say, from 30psi to 20psi). FYI, I'm referring to r134a systems if it makes a difference.
I thought about maybe trying to vacuum out the AC MGS & hoses before connecting them as a way to keep air out, but then wouldn't that simply cause me to lose more refrigerant inside the hoses, since the vacuum would suck out & fill them with refrigerant?
What's the best way to manage this for the DIY guy?
