refilling a large r134a self-sealing can?
Posted: Wed Sep 13, 2023 1:23 am
ok, i know this is going to sound crazy, and I'll probably get scolded for it, but I'll ask anyway...
A friend of mine gave me a large 35oz (1kg) can of r134a that he had left over from when he did his AC. I'm not sure where he got it (it's autozone 'shop pros' brand). It's a self-sealing can that's functional but is basically empty. I asked him where he got it and/or if he could get me another one, but he said he couldn't.
Anyway, this size can would be perfect for me to use to do the A/C on my truck (22oz), and it would avoid me having to deal with using two 12oz cans & having to purge the lines when swapping, keep track of exactly how much refrigerant I put in from each can, etc.
So, my question is 'can I transfer the contents of two 12oz cans into the larger one, by using a charging hose, a couple of can taps & ball valves?'
I was thinking I could first pull vacuum on the empty can, and then transfer over the contents of the smaller cans into the bigger can, using some warm water (or some other light heat source) to heat the smaller can & help the refrigerant expand into the larger one (and, also, by cooling the larger can in ice water?). Since the big can is designed to hold 35oz, and I'd only be putting in 22oz, I figured it would be feasible to get done without having to use much pressure & be within safe limits of the can's capacity.
Yes, I know this might be a crazy 'do at my own risk' type of activity, but I was wondering if the idea makes sense in theory, and/or if anyone else has done something like this before?
please help, thanks
please help, thanks
