10S20F Performance Chart
Posted: Mon Sep 11, 2023 4:12 pm
Hello,
Long time lurker and hoping I can find some information. Looking for a performance chart for the GM 10S20F compressor used on the trucks and vans. I have a friends 2012 Express Explorer conversion van that I am working on that has had 65-70°F vent temps at idle and only modest improvements in cooling at 70 mph on the highway since it was new. He recently asked me for help with it after having a GM dealership insist that it had a failing compressor and charged him nearly 3K in parts and labor only to end up with the same poor cooling. After performing the work they now claim it has acceptable cooling for the ambient conditions.
I own a 97 Express conversion that cools much better with a HT6 and now a Four Seasons 88947 HT6 replacement. You could hang meat in the 97 on 110°F Texas summer day. Same for my 83 conversion that used the old A6. With the A6 and the largest parallel flow I could fit in the grille opening on the 83, it blew ice crystals out of the vents at idle. That 83 still cools well with the Valeo HT6 replacement when I put an 8.1L into it.
I have checked the common stuff on the 2012. The low side pressures are high especially at idle. Fan clutch has been replaced with the OE towing unit, the condenser is a new GM and clean. The compressor was replaced 6 months ago with a new GM compressor. The system was flushed, both the expansion valve and orifice tube were replaced. The condenser and accumulator were also replaced. The dealership added a GMT400 pusher fan in the same manner as the GMT800 poor idle cooling TSB. I checked the pressures and temperatures and even misted the condenser with minimal improvements. I evacuated the system, installed a Red Ford 0.062" front orifice (which I have used for years in both my G20 and Express vans with rear ac) which provided a 3-5°F temperature reduction. However the suction side is still around 60-65 psi idle and 50 psi at 2,000 rpm. The high side never breaks 275 psi and dropped under 200 psi misting the condenser which only reduced the low side pressure an additional 5-10 psi. Long story short I believe the 10S20F is simply not keeping up with the evaporator load. I am considering replacing the 10S20F with a V7 for a LS1 Camaro and building lines for the setup. I have the chart for a V7 and before I attempt the V7 swap was hoping to find the 10S20F chart for a sanity check to see if the V7 would be an improvement. I know these vans can cool exceptionally well with dual air and all indications point to the compressor being the weak link but I want to confirm that diagnosis. I know the V7s can move some serious BTUs and the fact they do not have to cycle makes them cool very well. I have swapped the older S10 V7s into a couple of dual air R4 systems with great results.
