Robinaire 2.2 cu in vac pump - repairable?
Posted: Sun Sep 10, 2023 6:30 pm
by aribert
My Robinaire 2.2 cu in vacuum pump has become erratic and no longer draws below 1200 micron, at best. I completed 4 successive oil changes with no improvement. Are these pumps rebuildable by an individual? I searched for a repair kit or instructions for my pump and found nothing. I did find that Robinaire will rebuild vacuum pumps (I am presuming that this might exceed the value of an older pump).
I ended up renting one of the little vacuum pumps from a local auto parts store (actually I ended up doing this 3 times before I received a functioning pump) - performing several oil changes in each pump before giving up and returning to rent another pump. I'd much rather have my own pump if it were to function properly.
Re: Robinaire 2.2 cu in vac pump - repairable?
Posted: Sun Sep 10, 2023 7:58 pm
Posted: Sun Sep 10, 2023 8:18 pm
By the time you replace the vanes, rotor, static ring, and other internal components (if you can find them), plus your time to repair it, you'll probably come out ahead by purchasing a new pump, like the one above, which is also most likely superior in CFMs. Likewise having the company repair it, especially when factoring-in shipping, which will be expensive for such a heavy item.
Posted: Fri Oct 13, 2023 4:20 pm
by 3b auto
I hope your lasted longer than mine. Used mine x2
It got hot, and only pulled to -10
Im fresh oil will give it new life.
I still dont understand why your supposed to change oil with every useā€¦
Posted: Fri Oct 13, 2023 6:45 pm
3.102 Oil Contamination
The most common cause of a loss in efficiency in a mechanical pump is contamination of oil. It is caused by
condensation of vapors and by foreign particles. The undesirable condensate emulsifies with the oil which is
recirculated and subject to re-evaporation during the normal cycle of pump activity this reducing the ultimate
vacuum attainable
I answered in more detail in your other thread about compressor draining.
Posted: Wed Oct 25, 2023 7:56 am
by swampy 6x6
hi
Tried recently to repair my old school Robin air USA made 2stage 5 cfm vac pump . Parts are no longer made . The complete alloy pump half is replaced . Considered age and I chose not to
If u buy a non USA eg china buy a 6cfm 1/2hp 2stage. The 4cfm I purchased is slow to pull down vs my old school Robinair .
This is no reflection on site sponsor just my experiences with my personal setup .
