What's this stuff I'm flushing out of an evaporator?
Posted: Fri Sep 08, 2023 10:10 am
(I did read the he-cat-in flushing document mentioned the sticky above. I did use a 1qt flush gun because it is all I had)
Black chunks. If they are pressed they smear. My guess is solidified oil? Some have the shape of the outside of a tube.
The interesting thing is the round thing/glob. green on one side, black on the other. For scale, the round thing is about 1/4" diameter
This is from a 1980's VW Vanagon evaporator which has ben sitting for who knows how long (Will not be using this in my build)
This had ACPro Solvent cleaner in it for a week and then if was flushed several times and only on like the 4th flush this started coming out. The flush was re-used each time by straining through paper towel. Thought is to keep reusing the flush until bits no longer come out and then flush with non-used new flush.
