All new A/C System Parts--> Big problem - Help??
Posted: Tue Aug 01, 2023 1:58 pm
Hi all,
Restoring a 1994 GMC K1500 with 5.7 V/8. I installed virtually ALL new A/C system components, except the evaporator. I thoroughly flushed the evaporator, and pressure tested it for leaks. (None)
Vacuumed the system down for one hour plus, and then the system held the vacuum overnight with vacuum pump disconnected. I then started to charge the system as normal. Often times, if I work quickly, I can get enough freon into the system just from the vacuum, that the compressor will kick in and I don't need to bypass the pressure switch. In this case however, there was an electrical problem and the compressor didn't turn on. The system took a little under two cans on it's own, (about 20 ounces +/-) without the compressor running. Capacity is 32 oz. System calls for 8 oz total oil. New compressor came with 7 oz so I added 1 oz to new accumulator.
When I finished fussing with the electrical problem and got back to tending the gauges, things were all out of whack. The low side is pegged high, and when the compressor is on, the high side quickly (in about ~5 seconds) goes to emergency cut off at 450 psi plus, then the safety switch kicks in and turns the compressor off. Static, engine off pressures are Low side = pegged, High side = 150 psi.
After sitting over night, no change.
What's wrong here, and what's the fix???
