2010 Passat AC on the Fritz
Posted: Tue Aug 01, 2023 5:29 am
2010 VW Passat Wagon. 2.0 TSI CCTA. 6spd DSG.
Never fails that hot weather brings AC problems. AC stopped cooling last week. Research indicated that the compressor control solenoid valve was a likely culprit... for $45 bux plus 2 cans of r134a it seemed a reasonable gamble. Had the freon evac'ed (it was full... no leaks). Replaced the valve (almost conveniently located on the underside of the compressor). Vacuumed the system down for 60+ min. Verified it held 29+ for another half hour.
Then I started to fill (vapor fill on low side... I've since learned that's not the best way to start, but I digress). So it's a 600g system. And only got about 120g in before it stopped taking freon. Low side was reading high (between 80-90). I stopped filling and closed off the valves on the manifold and let the system settle. After 20 min, Low side was reading 85, the high side was reading between 80 and 85. Close enough to equal to determine compressor wasn't creating any pressure.
NOTE: Compressor clutch was engaged, manifold side of gauges were closed, port side of gauges were open. Hot air at the vents. Low side and high side tubing were both cool-ish to the touch.
ALSO NOTE: Before the evac, I hooked up the manifold gauges and noted an abnormally high reading on the low side... 200+. I don't recall what the high side was, but it looked to be at a normal range... probably around 200. This was with the car off, not warmed up.
ALSO ALSO NOTE: Full disclosure: The serp belt was chirping a bit when the ac was engaged and taking off from a dead stop. I replaced the belt and tensioner and the chrip stopped, but it did come back in the days leading up to the ac failure.
My guess at this point is that the compressor is knackered. It's never made any loud, rattling noises so I'm hopeful it didn't implode.
But how far do I go on the repair? Just replace the compressor? Should I replace the TXV and/or condenser as well? I know the "proper" answer to that, so let me explain... The Compressor and TXV are easily replaced on this car. The drier is integrated into the condenser. Excavating the condenser/drier however, requires darn near a complete tear down of the front of the car... bumper cover, bumper frame, headlights, radiator support... you get the idea. That's a couple days work for me. But I sure as heck can't afford to pay anyone to do it.
Can I get away with just a compressor (assuming that's the problem)?
