Jeep Liberty AC Cool Not Cold
Posted: Mon Jul 10, 2023 5:42 pm
2009 Jeep Liberty KK with 3.7l Engine
My story, sorry it's kind of long:
I had a compressor go bad on me a few months back, so I've been living with no Air Conditioning until I got the money to replace it. Out of an OVER abundance of caution, I replaced everything! The evap core, all three hoses, compressor, expansion valve, and condenser with drier.
When I got the new compressor I drained out the factory oil that it came with. It said it came with 4.4 oz. I for sure got 3oz out into a cup, and probably spilled another oz on the ground. I then carefully added new oil mixed with dye. About 3 oz to the compressor and 2 oz to the evap core. ( The new compressor instruction said to add half to the compressor and half to the rest of the system)
I carefully vacuumed down the system and it held at -29 psi for over 12 hours (got distracted by dad duties). Then attached the Freon (yes it was "Freon" brand R-134a) to the system. I purged the line, and then opened the low side and let the can fill the system with the engine off until it equalized. Then started the car and added the rest of that can, and 6 oz from the next can. That should be 18oz total, which is what the system sticker in the engine bay says it needs.
So here's my problem. With the ambient air temp at 83 degrees F, air conditioner on, fan on high, recirculation on. The air in the center vent only measures about 53-55 degrees F. According to the shop manual, it should be around 45 degrees at that ambient temperature.
Since there was some Freon left in one can, I added that as well. Now the system has about 20 - 22 oz in it, and still has the same
With the engine running, idling, and fully up to temperature, the pressure on the low side reads 30.5 PSI. The high side reads 170psi. These seem low. If I'm reading the Factory Repair and Service manual correctly, the pressures should be 27 - 37 PSI on the Low side and 225 - 325 PSI on the high side. So it seems a little low, right?
Not sure what to do here. From everything I've read it seems the most likely thing I did was add too much oil. I'm not sure what to do from here. Try adding more Freon? How much damage can overcharging the system cause? If I take it to a shop to evacuate and recharge the system will that remove the oil I put in? Kind of a moot point though as shops want $200 - $260 for the service and I don't have that cash right now.
Any input or suggestions would be GREATLY appreciated!
Oh, and I forgot to mention that with the engine off and cool, the pressure in the system is equalized on both sides, and is about the same as the ambient temperature.
Thanks!
Thanks!
