PAG 46 Potential problem??
Posted: Wed Jun 28, 2023 12:43 pm
by Whodunit
Hi folks! 1st, thx for the admit! I have what I believe to be a potential problem. While normally I would never mix different oils, on a recent job I went to add oil to a system prior to a charge. I happened to have 2 different styles of PAG 46, by that I mean one was your standard oil and the other had dye. Upon combining them they almost immediately separated out! I would have assumed being the save viscosity they'd mix easily! Apparently they have different specific gravities. Should this be avoided? Tia!
Re: PAG 46 Potential problem??
Posted: Wed Jun 28, 2023 1:14 pm
one of them must not be PAG
Posted: Wed Jun 28, 2023 2:45 pm
by Whodunit
That was my 1st thought! But no, they were both indeed pag 46 in the original containers.
Posted: Wed Jun 28, 2023 6:30 pm
Oil manufacturers have or use different oil add packs. Doubt you will have an issue as the oil will still circulate and should not lose its lubrication abilities.
Posted: Fri Jun 30, 2023 5:42 am
Interesting. Post the brands please.
Not a huge issue, the refrigerant flow will keep things stirred up and moving.
