A6 oil capacity after install with new filter/dryer
Posted: Tue May 30, 2023 12:35 pm
by WRSS-John
Working on a 1964 Corvette. I am in the process of replacing the A6 compressor and the filter/dryer. I am finding different requirements for the oil capacity. I am hearing I need from 3 to 10 ounces. Not much is draining out of old compressor. Do I fill the compressor at the little stub that has the plug or pour in the suction side? Do I need to add for the filer/dryer change? Thank you!
Re: A6 oil capacity after install with new filter/dryer
Posted: Tue Jun 06, 2023 10:51 am
The oil "total" capacity for an A6 is 10 ozs for a front-only system. You will need to account for any oil remaining in the system.
Posted: Tue Jun 06, 2023 11:28 am
WRSS-John wrote: ↑Tue May 30, 2023 12:35 pm
Not uncommon.
Not on A6, but when I've added oil to a new compressor, I first drain (through suction port) and measure how much oil is in the compressor. Then I add the correct amount into the suction side and manually turn the compressor drive plate slowly though at least 6 revolutions.
I've also flushed a couple of compressors for my still-R12 truck as those arrived with PAG oil instead of R-12 mineral oil (when I was working I could tell in 5 minutes the type of oil with one drop).
