Poor AC at idle - have pressures/duct temps
Posted: Mon May 29, 2023 12:33 pm
hey all,
long time lurker, first post on the forum.
I'm having issues with my 07 F-150 and it's A/C performance. it's a CCoT system. I did an engine overhaul and replaced the compressor with ford OEM, new condenser, suction line, orifice tube and pressure/return lines along with a new accumulator. I replaced the evaporator in the dash about 8 months ago. Holds vacuum at 29.5-30inHG overnight so pretty damn leak tight.
i have a manifold set, at 65 deg ambient, engine idle 675rpm i get this:
Low Side: 30psi
High Side: 225-250psi
Duct temp: 50 deg F
the temps eventually get cold after driving for about 15-20 mins but creep up again if coming back to stop/go traffic.
i think that the high side is too high and the low side isn't low enough which is why i get poor duct temps.
What do i look at first?
Low Side: 30psi
Duct temp: 50 deg F
