Bad Clutch or Bad Compressor?
Posted: Fri Sep 30, 2022 11:03 am
I have a Delco Remy compressor, Part number 15-22255 (also shows 8877492 on the label). It's about 10 years old. The AC quit the other day and, upon returning home, I found the composite material inside the clutch had shredded - it was completely gone. Car is loud, but I didn't hear anything unusual at the time the AC quit.
The damage to the clutch seems to be consistent with either a locked-up compressor or failure of the composite material - as I said, it's about 10 years old. The system is still pressurized, but I can turn the compressor with some effort by holding the splined part of the clutch remains on the shaft and turning by hand. Clockwise as viewed from the shaft end is a bit easier, but the compressor turns in both directions and I have been able to make complete revolutions.
This is a classic car that's still running r12 and while I have the tools and know how to evacuate the system, flush it then replace the compressor, drier and expansion valve, I really want to make sure that's necessary before committing the time and expense to do that. Any thoughts on whether replacing the clutch is worth a try or do I need to go ahead and bite the bullet?
Separate question: I haven't yet found a replacement part number for the now-shredded clutch assembly. The compressor design is not original to the car, so looking up parts by year/make/model doesn't work. This compressor has a splined shaft with a bolt to hold the clutch on the shaft. I'm looking for a kit with coil, pulley and clutch. Any suggestions on where I can find such a kit for this compressor would be appreciated.
Thanks!
Thanks!
