1999 Tahoe Low Side Cutting
Posted: Tue Sep 06, 2022 11:34 am
So I have a 99 Tahoe with C69 front and rear air. I've owned a few of these trucks and never fought the ac like this one. I'm running the 2.75lb charge as called out in my GM manual (I've also tried other volumes but this does seem to be the best with the newer replacement GM condensers)
What's happening is at 1500-1800 rpm it seems to work pretty well. However above that (2000 rpm) and the compressor cycling switch cuts the compressor at 22-24 psi like it should, however I'm only getting 50-55* air from the duct still. It will then head upwards of mid 60's duct temp and then turn back on. If I drive long enough it will start to get the duct temps down to the mid 40s but it takes a long while (30-40 minutes on a non heat soaked cab). And all of that is only if I have the rear air on. If I turn the rear air off, the system seems to cut the compressor even earlier meaning that I'm seeing my low side drop even more though and thus my duct temps may only average in the high 50' to low 60's at 2000 rpm. I've recovered and confirmed I do not have a leak in the system.
I can't figure out if I've got something going on with the rear air TXV causing my pressures to be too low when it's not running, like maybe it's hanging open some? Idling with both systems on with the charge at 2.75 isn't great either. If I just run the front only it does a little better. However if I drop the charge to about 2.5lb I can get better idling temps but it makes my cruising problem even worse. I just feel like I'm missing something.
I also tried going to a .072 OT from an .062 and that seemed to help my cruising problem a little but obviously gave up a little more on my idling temps.
Let me know if you think you need any more info, but I know these trucks can do better than this, I just think something is a miss yet.
Also, is there a way to test the TXV and if it's actually closing as far as it should with the rear air off?
