2016 Ford Explorer A/C leak
Posted: Thu Jul 21, 2022 5:50 am
Good Morning,
I have been working a 2016 Ford Explorer with front and rear A/C. I originally found the rear evaporator line leaking. It had oil, dye, and I could see it slightly bubble under pressure. After removing the subframe, and replacing the line I'm still not holding pressure. When I pressurize the system with nitrogen at 30psi I lose about 1 psi per hour. My concern is that when I raise the pressure of the nitrogen to over 36psi I hear it escaping loudly from an outlet on top of the compressor. I'm assuming it is the relief valve, it looks like a little square on the top side of the compressor. I'm putting the nitrogen in from the High side fitting. I was under the impression I should be able to get the psi up to 150 or so if needed. Could anyone help me with some advice???
Thanks in advance!
Thanks in advance!
