2007 Ford F350 AC issues.
Posted: Thu Jul 14, 2022 7:36 pm
This is my fiancé's Dad's truck that he bought used quite a few years ago. It has about 230,000 miles on it with what he believes to be the original AC components. It has the 6.0 diesel in it. It has been having intermittent AC issues where it would cool great for a while and then not.
He took it to a shop because he was going to have them replace the compressor because of the mileage and they told him the clutch gap was too wide and was causing the issue. They adjusted the clutch and replaced some shims or something and recharged the system. He said it still wasn't cooling correctly and that it was cooling better at idle compared to going down the road.
He brought it to the house so I could measure the vent temps and at idle with the blower on high, the vent temps were about 62 degrees on a hot and humid 92 degree day. I lowered the blower to low and the temps dropped to about 57 degrees. I also revved the engine up to 2,000 and the first time I did it, the vent temps went up to about 68-70 degrees at the center vent. One of the other times I revved it up that high, the temps went down to about 57 degrees.
This truck has a cycling switch with an orifice tube. I hooked up my scanner to it to look at the clutch circuit and cycling switch circuit while it was idling and at the higher rpms. At idle, both of these circuits stayed on. As soon as I revved it to 2K rpms or above, the cycling switch began cycling off at a rapid rate. I was graphing these PIDS and it looked like a square wave signal on both based on how often it was going on and off. As far as he knows, the cycling switch is also original.
My question is this, is this a normal cycling pattern at higher rpms for the system on this truck. It seems like it shouldn't be cycling that quickly or that much but I don't know how this system is supposed to work. Why would the vent temps sometimes go up at higher rpms with the cycling going on and off like I described and sometimes the vent temps would go down while cycling the same way?
This is an automatic heat/air system and the control module has been replaced with a new Motorcraft part not that long ago.
What else should we be looking at in the system? Thanks for any ideas or information.
