Oil Balancing System
Posted: Wed Jun 29, 2022 8:48 pm
Hello everyone,
Hope everyone is doing good.
Thought I'd try my hand again at fixing the A/C in another older family car after I had good results with the last repair I did on another vehicle.
The advice I received here was quite helpful.
Vehicle: 1995 Oldsmobile Cutlass Supreme
Engine: 3.1L, V5 Compressor
The main issue it had was a refrigerant leak, traced back to the high side port with the rubber ball GM uses, along with some oily residue on the compressor body which I assume to be a shaft seal leaking. My leak detector probe did not go off near it but I'd rather not risk doing the job again and a new OEM compressor was not as expensive as I expected, so I went ahead and bought another one. I also purchased new o-rings for the whole system, a new accumulator, high and low side port, and suction/discharge hoses for the compressor. I also bought a new condenser as the old one was badly bent in a front end collision (was not leaking, but wanted to be on the safe side).
According the service manual, the system capacity is 8 oz. They specify the following capacities:
Compressor - 2 oz if less than 1 oz was drained from old one, same amount as the old one if more than 1 oz was drained.
Condenser - 1 oz
Accumulator - 1 oz + what you drained from the old one.
Evaporator - 3 oz
The condenser is new, so that received 1 oz.
I drained about 1.3 oz from the old compressor, so that's what I put back into the new one after draining it.
I drained almost nothing from the accumulator, so I assume I need to add 2 oz back into it (to reach 8 oz total)
Evaporator is not being changed or flushed, so can I assume it has roughly 3 oz?
The manual claims small refrigerant leaks do not result in oil loss, but I feel as though I will not be at the system capacity when I finish adding the oil.
Is my approach correct? Any help is greatly appreciated.
Condenser - 1 oz
Evaporator - 3 oz
