Honda Thermal Limit Switch
Posted: Sat Jun 18, 2022 5:21 am
by Dgreen
Has anyone had any experience with these? I’m working on an 07 CR-V with intermittent AC. System works real good when the clutch engages. Clutch gap looks good. Pressures were 225 and 45 yesterday. It was a hot and humid day. I thought the compressor relay was bad. Changed it and it worked for a while and then started acting up again. Checked the area where the switch is mounted in the compressor and it showed to be 160 degrees. I looked for the part on ackits.com and didn’t see it.
Re: Honda Thermal Limit Switch
Posted: Sat Jun 18, 2022 6:57 am
Dgreen wrote: Sat Jun 18, 2022 5:21 am
Did you actually measure the AC clutch gap or just eyeball it ??? I ask because in 2019 my AC clutch was slipping sometimes on my 1998 Frontier.
There were two shim washers under the drive plate, so I removed the thinner of the two, then re-installed the AC clutch drive plate and that will make the AC clutch "gap" narrower (yet not so narrow that it scrapes in the disengaged position). Fine 3 years later.
Posted: Sat Jun 18, 2022 7:02 am
Right on. Use feeler gauges, should be about .020
Posted: Sat Jun 18, 2022 9:12 am
by Dgreen
I just looked at the clutch gap.
I found a mechanic on YouTube. He said Honda AC systems were prone to the thermal switch failing. I haven’t been able to locate the part. Looking like we may have to change the compressor. I will check the clutch gap with a feeler gauge before I do though.
Posted: Sun Jun 19, 2022 11:04 am
How hot a day was it? What was the ambient temperature in front of the grille? The reason I ask is that the low-side pressure seems a bit elevated for adequate cooling. What was the center-vent temperature while it was cooling good?
Posted: Mon Jun 20, 2022 5:59 am
by Dgreen
Vent temp was 45. I didn’t check temp at the condenser. Both radiator fans were running. Outside temp was 91.
Posted: Mon Jun 20, 2022 10:14 am
I don't think you mentioned this previously, but are you sure that the system is charged to the correct amount? This is a small-capacity system refrigerant-wise. So even an ounce or two low due to normal seasonal losses or a slow leak will negatively affect system operation.
Here are the specs that I have for your 2007 CR-V: 18.0 ounces net weight of R-134a and 4.5 ounces of PAG-46.
Posted: Tue Jun 21, 2022 4:39 am
by Dgreen
Thanks for the specs.
It isn’t acting like it’s low. Works good when it works, but when it quits, it might not work all day.
Posted: Tue Jun 21, 2022 6:51 am
Diagnostics trumps guessing.
Write back when you have measured the gap
Posted: Tue Jun 21, 2022 7:46 am
If the system is borderline low on refrigerant, the PCM might be seeing varying pressures, which change with the ambient temperature, just enough to shut down the compressor occasionally.
