Manual control of system for EV conversion
Posted: Thu Jun 16, 2022 2:57 pm
Hey all,
Converted a 99 Porsche boxster to EV.
Am building a Tesla EV compressor based system. Currently have the system fully flushed, proper oil, EV dye is on the way.
Originally I thought I could intercept the compressor clutch signal from the HVAC head, but Porsche uses the cars computer to actuate the compressor based on many different inputs.
I've been trying to fake out the computer because it needs things like Throttle valve position, RPM, coolant temperature, intake temperature and I'm not sure what else in order for it to operate the fans and clutch. Was making progress but it's becoming harder to figure out what inputs need to be faked out for it to operate.
My question is
The only input coming from the AC system is mean pressure and high low pressure from the pressure switch. H/L is easy it passes 12V when there's enough but not too much pressure.
But the mean pressure.... What is the car looking at there to regulate the compressor clutch?
I can build a controller if I know the operating conditions of that pressure switch.
Or in other words, how can you manually control a TXV system on a Porsche.
Jesse
My question is
Jesse
