2014 Honda Civic Si Sedan, troubleshooting help please!
Posted: Tue Jun 07, 2022 4:39 am
Hello everyone. I am hoping to get some help diagnosing some issues with my 2014 Honda Civic Si Sedan.
Original Symptoms:
No cold air, pressure readings spiking on the high side, 250-300 psi, would spike up quick. When that happened pressure would go almost to vacuum on the low side. 2 -5 psi.
After some reading and watching a ton of videos, I convinced myself that it had to be the expansion valve that was malfunctioning. Had a friend with a shop recover the refrigerant for me and I went ahead and replaced the expansion valve.
While I rebuilt the inside of the car, I had a vacuum pump running for about an hour on the system. Then I kept it closed for about another hour and vacuum pressure held. I ended up putting two 12oz cans of r134a and I thought everything looked good. My pressure reading at idle were, 40 psi on the low side, 164 on the high side. Outside temps were mid 80s and a quick test drive made made it seem everything was working fine. Nice and cold ac.
Current issues:
Day after I thought it was fixed, on my commute home, about 95 degrees, the system started venting refrigerant. It did this a couple of times and once again I am with hot air. The system as it currently stands, readings are from yesterday afternoon, about 93 degrees out, car parked in the garage after getting home from work. (Read, car is hot, about a 45 mile, hour 15 min. Commute in Texas heat)
Stabilized pressures before restarting: 105 psi
Stabilized pressure after ac running at idle for 10 mins: 53 psi on low side, 146 on the high side.
Accelerating engine to 1600 rpm: 9psi low side, 120 psi on the high side.
I took the rpm to 2k and low side went 0, and high side crept down a little. Didn't really let it stabilize so no good reading there.
I am a bit at a loss as to what is going on. The best I can figure is that either my drier or condenser are clogged. What do you guys think? Ac also seems to work fine on my morning commute, but I get in really early when the temps are still in the 80s.
Sorry for the wall of words and thanks in advance for those that stuck around and read all of it. Let me know if y'all have any questions.
Original Symptoms:
Current issues:
