Procedure for Nissan Leaf
Posted: Fri May 27, 2022 12:21 am
I've read the Evacuate and Charging procedure here.
I have a Nissan Leaf S electic vehicle (no heat pump). All the R134a has escaped.
I'm replacing the condenser (it has built in dryer) which had supposedly developed a crack but I have my doubts (but the system has been open to atmosphere for long enough that I expect the dryer needs replacing).
I'm also replacing the high pressure pipe which has definitely cracked.
I've flushed all the hoses and also flushed the evaporator (behind headwall). I have new R134a and the correct ND11 electric compressor oil.
The procedure from the service manual is listed below.
There is also a formula in the manual for how much oil to add based on what components are being replaced. The manual just says to do the math to determine amount of "Lubricant amount to be added to A/C system" and then "Install compressor and check the operation."
Since I had no idea how much oil remained I removed and drained the compressor. This means the entire system should be empty of oil. So I will need to add 150ml of ND11 which is the stated total system capacity (and 0.425kg of 134a)
My plan was to follow step 3 below, pull a vacuum and verify I don't have any leaks.
I've seen a video online discussing compressor (plus other component replacement) and they poured the 150ml of oil into the compressor assembly before reconnecting all the hoses but I'm not sure if it is safe to do this? Step 4 below implies to me that I should perform the initial leak vacuum test with the system totally empty, no oil, no R134a. Then add the oil.
I've seen videos where top off oil was poured into the yellow charging line before the R134a can was connected and the R134a basically blows the oil into the system. Should I use this same procedure to add the full capacity of oil or is there a different method?
Thanks!
Nissan service manual procedure.
1. Connect manifold gauge (for HFC-134a) to the service valve.
2. Connect vacuum pump to manifold gauge and operate the pump. Apply vacuum to the cooler cycle for approximately 25 minutes or longer.
CAUTION:
Evacuate air for 15 minutes or more if the parts are replaced.
3. Check the airtightness of A/C system for 25 minutes or more. If pressure raises more than the specified level, charge A/C system with approximately 200 g (0.4 lb) refrigerant and check that there is no refrigerant leakage. Refer to HA-26, "Check Refrigerant Leakage".
CAUTION:
Check the airtightness for 15 minutes or more if the parts are replaced.
4. If parts other than compressor were replaced, add compressor oil according to parts that were replaced. Refer to HA-29, "Lubricant Adjusting Procedure for Components Replacement Except Compressor".
5. Charge the A/C system from a service can with the specified amount of refrigerant.
6. Check that A/C system operates normally.
7. Disconnect manifold gauge.
8. Install A/C service valve cap.
9. Refrigerant charge is complete.
Thanks!
CAUTION:
CAUTION:
