Ac low pressure side is high and high pressure side is low
Posted: Fri Feb 25, 2022 4:46 pm
Last year the car started to blow the air a little warmer. I went to Walmart picked up one of those cans with the little gauges on it. The gauge said I was low so I filled it up. I had ice cold AC until this month. It started blowing hot again so I said I’ll just recharge it, the problem was when I bought the same can and put it on the gauge said that my system was overcharged. I went online and a lot of people were writing that you need a proper AC manifold gauges.
I got those today, plug them in and according to the paper it came with my system was low on refrigerant. I was about 30 PSI low side and the high side was 200 PSI. The manual said for 83 deg. 40-50 on the low side and 175-200 on the high side.
Started to put the refrigerant out the low side started going down instead of up. So when I saw that I stopped filling it. I was at around 20 PSI on the low side and 210 on the high side. I revved the engine and then the low side went to 90 PSI and the high side came down to 125 PSI.
Any ideas what this could be?
What I have noticed
I went to check if the compressor turns on and I noticed as soon as I turn on the AC it will blow cold air for about 1 minute and then the compressor starts to cycle on and off. It turns on for about 2 seconds and turns off and the car shakes. Then it does the same thing again until I turn off the AC or the car. If the compressor was bad would it still turn on and off? Also, does this sound like it could be a blocked expansion valve?
What I have noticed
