A/C stops blowing at stop lights
Posted: Mon Sep 27, 2021 5:40 pm
by Pete3323
Just got back from a road trip in my 1988 Ford Bronco 2. Worked fine on way to destination., about 3 hours away mostly freeway. A couple days in I started hearing a loud noise/vibration with a loss of A/C. On the way home it worked fine (no noises) on the freeway but once I got off and in street traffic I would lose the a/c when stopped. When it works it blows cold so I don’t think it lost refrigerant. Any ideas? Thx…
Re: A/C stops blowing at stop lights
Posted: Mon Sep 27, 2021 6:11 pm
by B52bombardier1
Either you have lost the radiator fan or the condenser fan that pulls heat out of the condenser or the compressor / compressor clutch is failing.
My two cent guess.
Rick
Posted: Mon Sep 27, 2021 6:50 pm
88 Bronco II will have a fan blade & fan clutch unless modified.
Posted: Mon Sep 27, 2021 8:59 pm
I'd be thinking about too large an air gap and possible bad clutch bearing
Both topics are covered well here, I would do a search
