Looking for advice re: 1990 Grand Wagoneer A/C
Posted: Sun Sep 26, 2021 5:09 pm
Am a brand new forum member & a n00b to A/C; am working on a 1990 Grand Wagoneer that came with non-functional A/C. From what i can tell, the previous owner bought the rust-free body as a roller & the engine (AMC 360) separately & had the two mated. The engine came with TBI EFI & A/C compressor (Sanden SD709) installed. The compressor has R134A fittings, making it appear to have had a R134A conversion done; while the body has what appears to be the 1990 original condenser, drier, hoses, etc. (more on this later).
A couple of months ago, I had the Grand Wagoneer at the shop to replace the oil pan gasket, and while they were in there, i asked that they check out the A/C system & let me know what needed to be done to get it going. They said the system was empty; pulled vacuum on it & it held. So they asked if i'd like it charged & dyed to help find any future leaks? Excited, I told them to go ahead (not taking the Frankenstein nature of the vehicle into account & that it was highly likely that only the compressor had the R134A fittings installed...) - ugh...
Shop noted that the discharge temps weren't very cold; to drive it & give a yell. Off to the parts store for a vent thermo, like my dad had years ago, to see what we were working with.
Disappointment: 70 degree air. This was on a 95 degree day after having driven for 45 minutes.
A few days later, i noticed a slight leak (neon green) on the compressor faceplate, making me wonder whether a compressor rebuild may be in order, and began reading various forums, incuding this one, as to what should've been done as part of a R134A conversion, including swapping the drier - which made me wonder...?? Surely not... Yep - 1990 factory original... ugh. Looks like i have a 1/2-swapped system.
Am thinking about going back to the shop to have the R134A removed, to allow swapping parts, but not sure where to go from there to get dug out of this? At this point, i don't have a set of manifold gauges. Should i get a set & see what the pressures look like before proceeding any further?
- First, there's the compressor leak; Have seen ACKits.com sells seals & gaskets to rebuild; and YouTube videos and the Jeep TSM showing the process. I'd like to try a rebuild - anyone had success doing this on a Sanden SD709?
- Then, there's the drier that needs to be swapped
- Hoses? etc.?
Compressor we're working with - sticker is mostly unreadable:
Also, looking at parts:
- Gasket sets: I'm seeing 2 gasket sets, one for 4.5" & one for 4.7". Short of disassembly, how do i tell which one i need?
- Shaft Seals: I'm seeing 2 types of shaft seals; a one-piece & a two-piece. Again, short of disassembly, how do i tell which one i need?
- Hoses? etc.?
