Just Curious / Now Guidance
Posted: Sun Sep 12, 2021 10:47 am
by akaDigger
So, I loaned out my beloved gauge set. I know, bad move.
The set was given to me by a friend thirty-five years ago. Probably one of his older sets then. (He was an HVAC technician) When I went to work on my truck today, I noticed that the low pressure gauge is resting at 45 psi when it should read zero. What happened to it? It's easy to suspect that it got over pressurized.
Re: Just Curious
Posted: Sun Sep 12, 2021 12:04 pm
Remove the front cover, may be glass or plastic. Sometimes they unscrew, sometimes they are pry off. Be careful.
Down at the bottom close to Zero you will note a slot head screw. This is a zeroing out adjustment for the Bourdon mechanism inside the gauge. Have at it.
I bet your set has a sight glass built in.
In a worst case scenario i have taken the back off the gauge and tweaked the Bourdon mechanism to reset, but this is seldom needed.
This is why I am loathe to loan my tools, they always come back broken. Now I tell ppl, buy your own then you can break your own
Re: Just Curious
Posted: Sun Sep 12, 2021 3:35 pm
by akaDigger
It can only be adjusted down to just below 40psi. I set it at 40 and subtracted that from read pressure. Of course I'll try the pliers.
I was actually just wondering what caused it to tweak so badly.
Re: Just Curious
Posted: Sun Sep 12, 2021 4:59 pm
Replace the gauge if it took a hit that hard. Low side R12 gauges typically have a 100 - 120 psi range and a snubber for those little "accidents".
When you hit one hard enough to bend it to 45psi permanently it may never register accurately again.
Newer 410a HVAC systems can see 350+ psi on the low side static on a warm day. And over 500 easily on the high side. If your friend borrowed it to work on the average mini-split...
Re: Just Curious
Posted: Mon Sep 13, 2021 7:39 am
by akaDigger
FWIW: The gauge is toast. I gave the Bourdon Tube a little nudge where I could dial it in to zero. Opened the can of r134a I had used last and high side went to 75psi, the low side to 100psi.
New gauge is cheap.
Re: Just Curious
Posted: Mon Sep 13, 2021 8:11 am
Bohica nailed it, your friend used it on his home AC, which is R410, which uses very high pressures, and killed it
Re: Just Curious
Posted: Mon Sep 13, 2021 2:02 pm
by akaDigger
Actually, he used it on a thirty-five year old R22 unit on his boat.
Re: Just Curious
Posted: Mon Sep 13, 2021 2:10 pm
That is odd, depending on ambient, he should have been around 50/250. Maybe as high as 60 on the low.
He did something wrong.
Maybe switched the hi and low sides by accident
Re: Just Curious
Posted: Mon Sep 13, 2021 6:55 pm
by akaDigger
tbirdtbird wrote: ↑Mon Sep 13, 2021 2:10 pm
That sounds like it.
Ordered a new gauge. After it comes in, I'll be back for help sorting my truck's AC. Which is cooling great by the way.
Re: Just Curious
Posted: Tue Sep 14, 2021 6:55 am
akaDigger wrote: ↑Mon Sep 13, 2021 6:55 pm
Never trouble trouble until trouble troubles you !!!
What's to sort out on that truck?????????????
