2004 Accord and 2011 Civic, evap freezing on both
Posted: Sun Aug 22, 2021 3:54 pm
Wife's cars, I drive 440K mile junk. The '04 is a garage queen with less than 90K+ on it, the '11 has just over 200K. Neither car has had so much as the AC service port caps off. Both exhibit the same symptom: Good cold air for a couple hours then the not so cold and the air gets a bit stuffy. Shut the AC off for a while and you're good to go again. Noticed there is a good size puddle of evap water under both cars after a couple hours on the road. We're in the dog days of summer with high humidity (NC) so I'm wasn't surprised to see icing of the evaporator so I hadn't checked pressures yet.
Got to thinking that both cars should have evap temp sensors? It's a low motivation Sunday today and it's hot and humid so, I did a quick internet search (instead of dragging out the gauge set) and it seems yup, they do have evap temp sensors. In the course of that search saw something about the Honda evap sensor output over time not matching the factory graph for temp and output in ohms. Evidently the sensors are a pain to reach so some have been measuring output and adding an inline resistor so the computer will shut off the compressor before the evaporator freezes. Is this a common Honda problem and common fix if the pressures are in line?
