Compressor does not cycle
Posted: Fri Aug 20, 2021 9:28 am
by canadmin
I am working on my neighbours 2014 Ram 1500 with 5.7 gas engine. The ac hasn't worked since he bought the truck a couple of years ago. I have replaced the compressor, expansion valve and dessicant bag. The ac is working very well now providing a lot of very cool air. High side pressure is about 225 and the low side about 35. However, the compressor is always running. It does not cycle off and on. Through my research, I've found opinions ranging from "don't worry about it" to "replace the ambient temp sensor and the interior temp sensor". I found the ambient temp sensor but have not been able to find the interior sensor. My question is, do I leave it as is or do I need to replace the sensors and where is the interior sensor? Thank you.
Re: Compressor does not cycle
Posted: Fri Aug 20, 2021 10:59 am
Ambient?
Posted: Fri Aug 20, 2021 11:09 am
A 35 PSI reading on the low side indicates an evaporator temperature of around 40 degrees. Was 35 recorded at idle? What are the low side and center vent temps at 1,800 RPM?
Posted: Fri Aug 20, 2021 1:00 pm
by DetroitAC
It's a variable displacement compressor, sounds like it's working properly. The clutch will not disengage as long as the climate control head is on and in a mode that calls for compressor on, or as long as the ambient is above freezing plus a little bit.
Posted: Fri Aug 20, 2021 1:10 pm
by canadmin
Thank you DetroitAC for not replying with more questions. Your explanation makes perfect sense to me because everything is working perfectly other than the compressor cycling and now I know that the system is indeed perfect. Thanks again.
Posted: Fri Aug 20, 2021 4:56 pm
